Mini Geiser in the Bilge
Haifisch
R-31 S
Pilar
Last night I was replacing the aft bilge pump cartridge. When I removed the screw that holds the wire loom cable tie, I discovered that the hole drilled for the screw went completely through the hull and resulted in a mini geiser of water of water spurting up. The hull is plenty thick in this area, but I think the driller went a little too deep.
Just a heads up to recommend you have some sealant on hand if you remove this screw.
