LADYBUG TOO
- Dec 9, 2010
- C-288 C
- FMLT2916B909
- LADYBUG, TOO
The ground on the forward cabin, port side 12 volt outlet is missing. I plugged in my CPAP only to find no power. Upon removing the outlet I found that the ground wire was never installed. Can I tie into the 120 volt ground? Or, do I need to run a ground somewhere else. The 120 Volt outlet is directly below the 12 volt so I could fish a ground to it. I am assuming that the ground is common to both systems. I am not sure what Ranger does with the neutral.
Pat, Ladybug Too
Pat, Ladybug Too
