GulfSailor
- Aug 25, 2011
- C-24 C
- Non-Fluid Motion Model
- Cutwater C28 / PDQ32 Catamaran
BaseCampAnne":2mdt7gob said:Interesting statistics and study you are doing on the zincs, Baz. I look forward to future results.
I am going to be interested in learning how the zincs last in San Diego. I believe the environmental standards are tougher in the marinas there, so perhaps the problems will be different, but I am becoming a skeptic. In addition, the water there is much warmer, which probably will have negative implications.
I am also guessing research results will always be dependent upon the marina, what the protections are for boats near ours, and how often other boats with problems are coming and going, sharing their "infectious" problems :-(
I have decided not to go with the galvanic isolator at this point due to the cost for having it put in, plus the 25 is a small boat. I am going to have a transom zinc put in, and have had the swim step bonded now, which should help.
I found it interesting that the 26 Cutwater comes with both the transom zinc and the bonded swim step, as I understand.
And the sacrificial zincs continue eroding...ah, what would we do if this were simple? :roll:
From your previous posts you sound like a resourceful lady. I don't believe it would be beyond your capabilities to correctly and safely install a GI yourself.
It's usually a case of drilling holes for four screws to mount it, then making a simple ground wire connection.
Take a look at the manual (which can always be found online), for the unit you favor and see what you think.
