Bennett does not require anodes on trim tabs in fresh water so there are not provisions for a anode from Bennett. Bennett does suggest that anodes be installed if the boat is left in the water, salt or brackish water. It is up to the boat manufacture to follow through with this recommendation. It is a production cost savings to not install anodes. Most reputable dealerships will install the anodes during the rigging process if they are aware that the boat owner will be storing the boat in the water and it is salt or brackish. With trailerable boats this is 50/50.
I would recommend installing anodes to the trim tabs regardless of use fresh water, brackish, salt or trailer. I do not recommend zinc anodes for trailerable boats. I do not recommend using zinc anodes for protecting outboards. I do not recommend using zinc anodes in fresh water. The aluminum will give better protection. The manufacture of Ranger Tugs and Cutwater does recommend for some reason. The reason zincs are not the best choice for trailerable boats or fresh water boats is the zinc will form an oxidation coating (calcareous coating),when introduced to air after being in the water or in fresh water. Once this oxidation has formed it will not be an active anode. The reason that zincs are not recommended for outboards is the zinc is slightly more noble than the aluminum alloy and doesn't provide as much protection. Pound to pound aluminum has a much higher longevity.The relative energy capacity of zinc is 368 amp hours per pound with a voltage of negative 1,050 millivolts.The relative energy capacity of aluminum is 1,108 amp hours per pound (significantly more than zinc), with a voltage of negative 1,100 millivolts. If you opt for aluminum anodes, be sure that the change is universal.
This is my opinion. I am not an expert on this subject. I just have opinions based on the subject. Zincs were fazed out in the late 80's early 90's by some outboard manufactures. Mercury marine voided the corrosion protection warranty if Zinc anodes were used on their products. There are many articles available to research the best anode protection for the type of equipment you have and the water you run it in.
