On your 21 you should have two fuses if it is wired as mine is. One is at the battery and leaves the battery and goes straight to the bilge pump float switch. The wire should be brown. The other wire at the pump comes from the switch at the helm. The wire from the float switch and the wire from the helm are tied together at the pump. The wire from the helm should also be brown. The switch at the helm is fused at the panel and should be labeled unless your boat was wired late on a Friday afternoon. 😉 If you could find a lighted switch that matches the ones at the helm (I could not) you would know if your bilge pump was on from the float switch as it would be back fed from the float switch.bjp447":1jrhrbqs said:Where is that inline fuse?
I think this is a good tip Jim. While this one may seem obvious to me (coming from an RV background), it will not be so obvious to other newbies.trailertrawlerkismet":1yeusaib said:Dock side water hookup has nothing to do with the bilge pump but I think it's been determine it best to leave the bilge pumps on, so I wanted to add something about water hookup. Our R27 has a dockside fresh water hookup that when one connects a water hose to it you're hooked up just like at home and have fresh water all of the time and no water pump noise when running water. The downside of this is important to understand. If an internal boat water line breaks you'll have non stop water coming into your boat that your bilge pumps will not be able to keep up with.(assuming they have been left on) Its best practice to turn the water off at the dock when you go away from the boat, if you've hooked it up, as a precaution against potential flooding. Our R27 is a 2012 so newer models may not even have a dockside water connection.
Jim
