Hello Cruzerboy,
WELCOME to Tugnuts! I see this is your first post. GREAT question.
As others have said CHEAP is fine. If you appreciate finer tools then Fluke is an example of a "premium" brand.
I recommend a "clamp-on" style meter. It will come with probe cables so I can be used to measure voltage or resistance same as the non clamp style. The benefit of a clamp on is that it will allow EASY measurement of current...like if you have a 'problem' battery, start your engine and clamp your meter on your charging wire coming from the alternator...you will immediately know if the alternator is providing appropriate charge. Turn everything off and clamp each wire coming off the positive battery terminal to see if there is a "parasitic" load that is draining the battery. LOTS of uses for the clamp on style. Amazon has oodles but they are also avail at Lowes, Home Despot, even walmart. When getting the clamp on style make sure it will read DC current (some read only AC current).
Fair winds and meters,
/david
