GaylesFaerie
- Jul 20, 2020
- C-28
- FMLT2701D112
- Gayles Faerie
Not surprisingly Gayle's Faerie (2012 R27 Classic) lost her prop zinc this past season which as I've read on the forums is a pretty common event. On haul out, all that remained was the toothed washer with an itty bit of zinc on it. The allen head nut held fine with the thread lock I applied. I had painted the prop and rudder and I didn't notice any corrosion, so am counting myself lucky.
I've seen all the prop zinc remedies on Tugnuts and the fact that there are so many and they work for some and not others leads me to want to add a reliable backup for protecting the prop, rudder and shaft.
I'm thinking of adding a shaft brush and wiring it (8 AWG) directly to a transom zinc but am a bit confused by all the solutions I've seen on Tugnuts.
Shaft brush: https://www.suremarineservice.com/Elect ... SB-6B.html
Transom zinc: https://www.boatzincs.com/Vetus-8.html It weighs 2.2 lbs compared to the 1.6 lbs of the D size Prop zinc and only requires a single bolt keeping things simple.
I assume the wiring configuration above would protect the shaft and prop. But what about the rudder? Would I need to run a second wire from the transom zinc to the rudder? or would going to the bonding bus bar protect the rudder (and other underwater metals as well)?
I'd appreciate any critiques / advice. Thanks, Gary
Bonus question: does anyone know what material the stringers under the engine mounts are composed of? I would be installing a small piece of starboard on the stringer to fasten the shaft brush to and don't know if drilling into the stringer will hit only fiberglass and wood or is there metal plate along the stringer? Or is drilling not necessary and something like 4200 would suffice?
