Chimo
- Oct 24, 2016
- C-26
- Chimo
I posted this under General Technical Discussions but I would be really grateful if I could get some input from the factory. No complaints, just looking for info.
Background: Last month I updated the software on the Garmin GPSMAP 7610xsv on our 2017 R25SC without any apparent issues. Last week I was on day three of a trip and tried to use the Autoguidance for the next leg , something I had been doing regularly. The route was created as usual but the pop-up window to engage the autopilot was missing. On the autopilot screen there was no option to 'Follow route'. Obviously the two units had stopped talking. Fast forward to yesterday where after an hour or so on the phone with Garmin support (very helpful people) the autopilot tech. deduced that unit had got a bit confused (my words) during the software update. Apparently it's happened before. The solution, "Go to your NEMA 2000 backbone".
So: First question, on this boat where is the NEMA 2000 backbone located? I couldn't find it.
No problem, "Turn off your plotter and then turn off all your DC breakers. Turn off the DC master breaker." Did this only to find that the GC20 autopilot display is still powered. "Turn off your house battery." OK, that done the GC20 shut down. Waited the required 10 seconds and then powered everything back up. Result: Autoguidance working fine, happy customer 🙂 . If anyone else has this issue I hope the above may be helpful.
So: Second question, where's the best place to install a power switch for the NEMA 2000 backbone? Can it easily go through a spare 'Accessory' breaker on the DC panel? As the Garmin tech. pointed out, if the backbone is continuously powered and there's no shorepower available then all the sensors etc. are still draining the battery. A user may think he is only powering the fridge and calculate battery use on that basis alone but there's actually an additional, presumably small, load on the house batteries.
