I have just purchased a 2010 21EC and have some electrical questions.
1. There appear to be small led lights along the edge of the hull at transom and above the steps all on the outside of the hull. They do not light up? Is there a switch or fuse for these? They do not light up when you turn on the Deck Light switch.
2. My ProMariner ProTEch charger is buzzing loud (not normal charger hum). Lights are normal as is charge voltage. Any ideas?
3.Both air horns are dead....where would they be fused from? All fuses in fuse block are ok.
4. There is one spot on the fuse block that has a wire to it, but no fuse. When I put a fuse in it, the starboard windshield wiper turns on and won't turn off. With the fuse removed...all three wipers work normally using their buttons. It appears that it is a circuit that runs direct to one wiper only with no switch...
5. The Yanmar panel is only partially working. I am replacing with a panel from AC DC Marine in California that has real oil and water temperature gauges with alarms instead of just idiot lights. Anyone else do this upgrade?
Thank you,
Harley
Thank you,
Harley
