New owner
Sandpiper
Cut Water (30)
Sandpiper
We have just purchased a 30 foot Cut Water are there any suggestions that any one would make to help break in a brand new vessel? Any and all suggestions would be greatly appreciated.
Thank you,
Bob
Sandpiper Ikl
Welcome to the Tugnuts Forum Bob and Ann. Although I have no specific suggestions for your new Cutwater, I'm sure fellow Cutwater owners will chime in. Just so our fellow members know Bob and Ann are seasoned boaters, have completed the Great Loop a few years ago on their prior 44' Endeavor. Bob and Ann have a great deal of knowledge and boating wisdom to share with all of us and will be a welcome addition to our Tugnuts Forum. Congratulations on your new 30 foot Cutwater.
Jim
I assume your question is about the engine and transmission.
Breaking in the engine and transmission and cutless is not specific to any boat make - and is no different than a new vehicle.
This is my way over the first ten hours
Run it frequently. Run the engine at various power levels for the first two hours - changing from a slow cruise for 10 - 15 minutes or so, 3 to 5 minutes of wide open throttle, then maybe ten minutes of medium cruise, etc.
You get the picture. Let the moving parts do the initial couple of hours of wearing in against each other (called break in) at various speed and power levels. Just change the throttle setting every 10 to 15 minutes for the first couple of hours. Then for the rest of the initial ten hours remember to vary your RPMs every 20 minutes or so and limit full throttle to short runs of less than ten minutes.
After ten hours - which roughly equates to the first 500 miles of 'break in' called for by your auto maker - change the engine oil/filter and you are good to go. Enjoy.
In my case I have a tendency to drift along at 6 knots 99% of the time (which is barely above an idle) and I have to remind myself to open the throttle for a few minutes to clean out the carbon and exercise the turbo. Diesels do best when run under enough load to keep them hot.
There is also a break in period for the engine mounts. The rubber in the mounts will compress a bit. Somewhere along about 50 to 100 hours your manual will call for having the alignment checked. This is an excellent idea. And you can check it yourself. I will not go into my usual tendency to describe it in detail. You can find instructions with pictures on the internet.
cheers, eh wot :mrgreen:
Hi Bob- not a tug owner yet, (looking at one this weekend!) but this website from John and Laurie Grey is fantastic for ideas and helpful hints.
http://www.andiamo-ranger29.com/
They have really been helpful for me.
jeff
