Next Gen Coolant Change
Bosn Mate
R-29 S
FMLT2912I718
Tingira
I am in the process of changing coolant on a Next Gen generator manufactured in Aug 2017. I sucked the coolant out of the fill/check tank.
According to the manual, I need to open a drain cock on the bottom of the generator. However, it appears that if I do, coolant will run out freely into the bottom of the sound proof enclosure.
Is there a trick to capturing the coolant after I open the drain cock?
Thanks!!
