bawerner
- Jul 12, 2018
- R-21
- FMLC2618A515
- SADEE
2015 C-26 with generator has major electrical issue. No power when when I put rotary power panel switch to Inverter or generator. Shore power works, but the reverse polarity light is on. The generator control panel has no power to it either.
There is also no power to the breaker under the microwave. I've checked all the accessible fuses on the panels and the fuses connected to all the batteries. House batteries work fine, engine starts, all the batteries are putting out correct voltage. Is there a circuit breaker I haven't found or fuses on the back of the power panel?
Where is the inverter? The diagram shows it near the battery charger, but all I see is the water heater there.
Battery Charger is working when shore power is on.
I believe this happened when someone in my family took a 120 volt room heater to the boat and plugged it in. Probably overloaded something. The next time I went down there the breaker on the electric meter was tripped and there was no power to the inverter or generator. Before that everything was working perfectly. Anyone have any ideas?
