CaspersCruiser
- May 11, 2016
- R-27 Classic
- FMLT2709G112
- Cookie
It’s been a couple of red letter days on Ranger Tug “Cookie”. When the thruster battery switch was turned on a few days ago, the bow thruster started running without command. To isolate it, today I disconnected the bow thruster by removing its 150 amp fuse below the thruster battery switch.
After I did that, there was no power at the Main DC Distribution Panel at the helm or to the Dash Fuse Block. I reinstalled the bow thruster fuse, but there continued to be no power to the DC Distribution Panel. The voltmeter at the DC Distribution Panel indicates normal battery voltage on all three battery banks, but no power is present at the DC Distribution Panel or Dash Fuse Block. When I removed the bow thruster fuse, there was no sort of arcing or electrical distress. I have no clue as to the relationship between the two events. DC power is available to the cabin overhead lights and lamps over the dinette so some DC power is getting out from the batteries. The AC Distribution Panel is operating normally via shore power.
From my study of the wiring schematic, it seems the common point of failure here is a 100 amp fuse between the House battery switch and the Main DC Switch Panel. Can anyone tell me where this 100 amp fuse is located? Does anyone have a clue as to the relationship between removing the bow thruster fuse and no power to the Main DC Distribution Panel?
