quinsky
- Jul 25, 2017
- R-21 EC
- FMLC2813H
- Compass Rose
Recently I lost power to the three starboard AC outlets on my CW28. They were working fine using the inverter just two days ago. Ive been doing a lot of work on the boat so I checked for damaged wires but found none. The switch on the main panel is lit but I don't hear the inverter kick in when I turn the switch on (like it does when I turn the port side outlets on). The port side outlets are working. The ground fault in the head is not lit and will not test or reset. It seems that if I damaged a wire the breaker would trip or I would only lose power to one or two outlets vs all three. I pulled the main switch panel but didn't see anything amiss. Is there a breaker between the switch panel and the outlets? Could it be a faulty breaker? I don't see an AC schematic in the manual.
