Nova Cool refrigerator
C-248 C
FMLT2538K809
Tug-Lee
Does anyone know how the little door that covers the freezer compartment is attached and what are the 2 nuts and bolts located on each side for. My door is just wedged in and falls off all the time. Second question, a cleaning crew broke the hinge on the skylight over the head, Jim Black wants to sell me the whole unit, has anyone ever repaired one?
Jeff
Jeff: the door is attached at the top where it hinges out at the bottom and rests on the 2 studs/screws at the bottom. There is also a small L-bracket that is attached snugly that swings up to "lock" the door shut. Mine is appropriately attached, but even so, it is flimsy at best. Hope this helps.
Good luck.
Dan
I looked at mine and it almost looks like they used a pop rivet in reverse with the metal nail part attached in a grove and the un-squashed rivet against plastic washers. You may want to give them a call. I have found them pretty responsive and perhaps they can point you in the right direction.
