LADYBUG TOO
- Dec 9, 2010
- C-288 C
- FMLT2916B909
- LADYBUG, TOO
I had this great "eureka" the other day and like so many before it, I am not sure I should have wasted the time. Anyway, I decided to compile a list of all nut and bolt sizes key to my salvation in the middle of nowhere. It started in the bilge with the engine and I started trying sockets, box wrenches and the like. I needed 30mm for the engine mount adjustments, 24mm for the transmission drain or was that 22mm. Then I needed a 3/4 inch for the coupling bolts. Then, confusion reigned supreme. If I load everthing I think I will need the boat will sink! Has anyone come up with a good tool box suggestion fro the R-29 with the 6BY2. I am not sure that they are even consistent from hull to hull but with a better starting point I might be better prepared. If not, I will post mine when I get it done.
Pat, Ladybug, Too
Pat, Ladybug, Too
