The Bolton Wanderer
- Mar 8, 2020
- C-24 C
- Non-Fluid Motion Model
- Hunter 260 Sailboat
- Sail La Vie
There has probably been much discussion over this subject so if someone knows where to point me I'd appreciate it. My question is for those of you out there that live in the PNW,
or have experience boating in colder climates. We live in Idaho and are considering a move farther north in Idaho or to the Puget sound. If we purchase an FM boat it will likely be a 10ft beam and we will for sure want to tow it to take in parts of the loop and other destinations. All other things aside, our question revolves around should we go for an OB boat or IB.
On the Cutwaters of course we have a choice, but once we hit 10ft beam on the R29 its Diesel like it or not..
The thing is, I see as, doing some cruising in the winter as it can be beautiful and quiet in the Sound during Fall and Winter so we are weighing up what is best for us..
Upsides on the OB, I see as no winterizing between trips out of the water (Pretty huge factor) available speed if necessary, more space in the lazarette.
Downsides are larger berth fees, longer unit to tow, looking at those two big lumps when on the hook, 2 or even 3 different fuels on board, no motor produced hot water.
Upsides on the IB, I see as, likely longer engine life if ran at lower speeds (Which would be our choice) "Slightly" better economy at hull speed, shorter slip/berth/towing, better view off the cockpit and easier tender options, hot water from the motor, more affordable and available used options for purchase.
Downsides are less storage, harder to maintain,... and what? What am I missing and what are your thoughts/experiences?
Cheers, The Bolton Wanderer.
