NorthernFocus
- Jun 29, 2014
- Alaska
- Website
- www.northernfocusphotography.com
- R-25 Classic
- FMLT25910808
- Divine Focus
We installed a Raymarine EVO AP last year. We put over 200 hours on it last season and it worked flawlesly. And continues to do so this season... for the most part. But every once in a while it does something really weird. I haven't noticed a common set of conditions when it occurs other than most of the time it occurs within five minutes of switching to AP control. But it has happened once or twice after the AP has been in control for an hour or so. The symptoms are as follow:
- AP operating in "course keeping" mode (i.e. not integrated with GPS so no route following)
- boat drifts off course and AP starts to correct as indicated by display
- rudder turns in opposite direction of indicated course correction
- AP continues to attempt to correct with harder rudder command and rudder goes harder over in opposite direction
- this behavior continues until AP command indicates hard over in one direction and actual rudder goes hard over in opposite direction
- during this event compass heading appears accurate and AP appears to be trying to do what it should be doing but the rudder is responding in reverse of the AP command
This is really a weird situation when it occurs. It seems to be a hydraulic problem rather than electronics. But I can't imagine what could make it behave this way. Haven't had any issues with manual steering and even during this event the manual steering will function normally if you turn the wheel.
Any ideas/suggestions/etc that anyone can offer would be greatly appreciated.
