nzfisher
- Jan 26, 2009
- R-25 SC
- Swims with Tuna
So the best thing about owning a Ranger is right here- expert knowledge base of users ready to share their combined knowledge and history. That being said I was witness to some bad news today- not a heart attack but close in the world of boat ownership but truly a first world problem. Luckily I was starting the boat on the hard to prep for Poets cove trip which now seems dubious. Big sigh here. Started the boat and it started right up-probably a year since it was last run. Everything looked good but then I noticed a lot of oil in the bilge. Given I just cleaned it last night, ( had more oil than usual then), it should not have so much oil as it was pumping out now. A lot of oil, perhaps half a quart in the three to four minutes of run time before I shut it off. So I put it out there for probable causes so I can benefit from other’s experience. The boat has about 1100 hours, 2011 Yanmar 150 power plant. I vaguely remember someone in the past talking about an little known oil plug near bottom of engine that hod come loose. I am hoping this is the culprit. There is no sign of oil in the coolant system and the engine started right up and rain smoothly so cracked block seems unlikely. The engine has been carefully maintained and rarely run over 3000 rpm throughout its life. I am original owner. Any help would be appreciated. As a footnote the boat has started to smell of chemicals for about a year so it seems likely that a plug started to slowly pass oil. If someone knows where this plug is on block that would be a good place for me to start or other probable causes would be great.
Swims with Tunakl
Swims with Tunakl
