PuffinStuff
- Feb 9, 2014
- C-288 C
- Puffin
Hello,
We have a 2012 R-29 with less than 200 hours on it and recently the oil pressure started showing wild readings while underway. At first, no pressure whatsoever (even though oil levels confirmed), then spiking to as much as 200, before settling down into a typical range of 60 - 70 at 2,800 - 3,000 rpms.
I've been told by other Ranger Tug owners that this is a common complaint with Yanmar engines and that it's simply a sensor, but I wanted to see if this was indeed common as I don't see a lot of threads on this topic on the forum. Going away for the 4th and want to be sure I'm not risking calamity by having it seen to ASAP.
Paul
Paul
