Older C26 - aft water "jet"?
Diatom
R-21
FMLC2613A111
Misty Blue
Sudden onset: wake/rooster tail suddenly includes an asymmetric water "jet" shooting up/back from port aft corner.
The "jet" is more intense than a full-blast garden hose. It impinges intensely on my 7' dinghy lower pontoon (dinghy on weaver risers above swim grid, pontoons on port side). This is not the typical low-speed burbling swim-grid flood, it's like a small fire hose on port side only.
Conditions: high speed 3580 RPM 30 kmh tabs down considerably. Normal temp 196F. Wake looks otherwise normal. Tab performance normal/responsive/level. Speed on familiar route seemed a couple of kmh slow, could be current/wind. Just filled with diesel, solo cruise. No known impacts, no obvious impacts on BRNKL log past 7d. Lots of kelp & crap in the water. Prop behavior seems normal - no unusual vibrations etc. From swimgrid I see a fair amount of seaweed starting to recur on tabs. Rudder looks/behaves normally. Recent trips have included some pretty heavy waves in Georgia Strait and shallow sand off Sidney Island. Recent starboard-tie Steveston mooring port-exposed to river flow, lots of debris. Exhaust flapper in typical condition, mobile but at rest is half-open. No finger-palpable obstruction in distal end of exhaust. Not listing, near-empty bilge as usual.
Any ideas?
/tmm
It is from the exhaust port relief. All Cutwater and Ranger inboards have this issue when going at speed. The dingy needs to bemoaned off set favoring the starboard side and mounted about 4" tiger than the platform. If not you are going to get a shower in the cockpit!
Thanks Brian - was terrified that something bizarre was going on with exhaust or a trim tab was failing. Tested exhaustively yesterday, the "new" intensity seems to be... my dinghy shifted. Dinghy has a lot of play on the weavers, so I had a couple of flat bungees contrived to favor starboard; they've lost elasticity & I guess it suddenly tilted back to port. Shower indeed.
/tmm
Instructive thread you pointed to. My bungees are a pale imitation of your straps - had to do a cats-cradle tension thing to get around my lack of a rail on my swim grid.
/tmm
