DBBRanger
- Mar 31, 2013
- R-25 Classic
- Still Crazy
My horn stopped working so I followed the instructions from the manufacturer that have been repeated here. I got to the part in the instructions where it says to go back to srep 2 if sanding the contacts doesn't work - ie, loosen the adjustment screw. I had to loosen it a considerable amount before it started working again. Infortunately, by that time I was lost as to where it was set originally. Although the horn is working, it didn't have the rich tone that it once had. I emailed the manufacturer to see what frequency they are set at - apparently not a question they usually get. After much ado, they said the settings are:
370 +/- 20Hz ; 320 +/- 20Hz
I got an android app that shows frequency, but have not been in a position to play with it yet, especially since the horns don't sound too badly now. A quick test showed that it still might not be easy to adjust them since they don't produce a pure tone. I just wanted to put this out there in case others had the need.
