Opening electrical panel
rehurst
C-288 C
FMLT2921J112
Feisty too
I do not see the tabs referred to by others in opening or unscrewing the panel. Concerned about just prying up the panel. Have a Blue Seas breaker panel.
Rich Hurst
Feisty Too 2012 R-29
At the top of the panel and at the bottom of the panel are two convex pieces of plastic, two above the meters ( one above the 12V and one above the 120V) and two below the breakers. Hold the plastic and slide it out. The screws are under there.
Mine have 12volt DC and 120 volt AC written on them, they just pop off... Make sure you are disconnected from shore power and the inverter is off, before you start poking around in there.. There is not a lot of slack in the wires. Before replacing take a quick look on the 12 volt side and make sure non of the bayonet connectors have pulled off.. Saves going back when something quits working.
Good Luck
