Out Board Motor Mount
Charlie rASMUSSEN
C-248 C
FMLT2588c808
Lone Ranger
Is there a out board motor mount available for a long shaft (15") outboard for a inflatable?
Can you be more specific? Where to you want to mount the motor, to the dingy, the stern, the rails, for storage?
I have never seen such an animal. I think you are out of luck mounting a long shaft on an inflatable. The motor wont run right if at all if you tried. Too much back pressure.
Hi
I thought 15" inch is standard length and 20" is long shaft motor.
My 15" shaft motor works just fine.
Dennis
Tug of my heart II
15" is the standard shaft. If you want to use a long shaft (20") you can laminate a piece to the transom of the inflatable to raise the mount 5". I would either bolt it, with metal plates on both sides of the old transom and the extension.
Bob Austin
Pensacola, FL.
