I had a Groco SSC-1500, 1 1/2" engine flush kit and adapter installed on the raw water intake line directly after the strainer. I use this to connect a garden hose to a five gallon bucket of either freshwater or freshwater with some salt away added. I then start the engine and let it syphon it down. I also quickly move the hose to a second bucket and syphon that down and then cut the engine. I'll let that sit until I fire it up again at a later date. I've also used Barnacle Buster with this same method.
I know that others use systems that continuously cycle the solution through, but I think this approach helps reduce minerals and some marine growth and only takes a few minutes. Make sure that you close the sea cock when syphoning and then more importantly open it back up when you plan to start up!
I see that you are in Port Ludlow. I had Gold Star Marine in Port Townsend install the Groco for me. They are just a 45 minute run from you due north. Ask for Caleb or Kaihla. Or, Personal Message (PM) me and I would be happy to show you in more detail how it works for me. Sorry I don't have any photos handy.
Paul
