pets on board - eliminating shore visits
jraftery
C-302 SC
Endeavor - RT 43 CB
So, I searched and do not see anything in the forum on this topic. We have two small dogs and are planning some longer trips. Has anyone been successful in having the dogs use artificial or real grass trays/mats to relieve themselves on the boat? We will be in a marina or on the hook at night and able to get the dogs ashore then - but if we are doing 8 hour travel days, we would like to have the dogs use the trays - and not require a potty-break stop.
Feedback on what others do to facilitate the dog(s) companion would be appreciated.
John
Jeffery Siegel the guy who invented Active Captain did a paper on training a dog to relieve themselves on a boat in the desired spot. Go to takingpaws.com/p/blog-page.html for a copy of his paper.
We put down a patch of fake grass for our three dogs (two miniature pinschers and a papillon). All three simply did not want anything to do with it. Then I read that you need to contribute as well to get them used to peeing on it.....remember they have been trained not to go indoors so they feel the same rules apply. Anyhow I put the grass mat out on the swim grid and peed on it 4 or 5 times before the pinschers caught on and started using it. The pap never did catch on so we still had to make shore trips for her. Admittedly it felt a little odd to pee on my swim grid but it worked so just passing the tip along.
We have trained our doodle to do this with fake grass (and a first time "example" as noted). It is very useful in times of bad weather, etc. Occasionally takes a bit of prompting or waiting until later for him to refresh on the expectation.
In fact the training was so successful that one time he found and used the same grass that was stashed in the garage, when we weren't paying attention! Much harder to clean up there!
We use this item (see link below) with artificial grass on the boat for our 60 lb female Labrador retriever. She has no problem doing her business (either #1 or #2) on it. The grass cover is easily removed and cleaned and pee collects in a tray below. We did train her to pee on command when she was a puppy (i.e. taking her into the yard when she needed to go and saying "do your business" several times so she knows that's what we want her to do when she hears that. I think that early training helped a lot when we got the tray to encourage her to use it. I've heard that if you have a male dog that putting a small bush like object on the pad for them to pee on can help also.
https://www.amazon.com/gp/product/B002D ... UTF8&psc=1
I believe there are plastic "fire hydrants" precisely for this purpose. 😀
We are planning to bring our small 2 month old kitten aboard and “hope” to train her to use a litter box in the cockpit.
Anyone have any advice on bringing cats on short cruises?
We have taken our cat(s) on boats with us for decades (even wrote a book about traveling with one of those sweet felines: "Cat On A Leash"). Most cats do well with a litter box, but it is important to give them consistency. Start with the same litter box you use at home. If your cat is using that box well, plan an overnight on the boat where you don't move (on the trailer will work, but at the slip is good, too). Let the cat get used to these new surroundings, show him/her where the litter box is, and have a quiet evening on the boat. After a time or two of this, while one of you can keep the cat comfortable, start the boat and let it idle until the cat isn't concerned about these new sounds. Pick a calm day, and do a short outing, where the cat gets a treat or a meal while out. Back to the dock and more quiet time.
By this point, you are ready to take on more and so is the cat. Still, avoid any rough weather until the cat is well acclimated to the boat environment.
Our cats (one at a time) have traveled all over the US and into Canada and Mexico. Up to 6 months at a time in the boat or RV. On our last cruising boat, our cat Izzy got to have one compartment just for her litter box. I took the door of the lower cabinet and put a curtain across there - she got her privacy, and we didn't have to look at litter. The only downside of putting the litter in the cockpit is: the cat has to be in the cockpit to use it... you have to be out there with her to keep her safe. In an inside compartment, the litter box is accessible any time. If you decide to go out for supper, the cat is safe and comfortable in the boat... with access to the litter box. From experience: if a cat has to go potty and there isn't a litter box available, they will find the next best place: in a plant, on your pillow, on the rug... not a good way to get them started.
If you haven't tried it, the Breeze system for litter works great on a boat. It uses pellets that dries out the solids and keeps the smell to an absolute minimum, and a pad in a tray under the litter box to absorb the urine (which passes through the pellets above). A little more money than typical clumping litter, buy well worth it. Once a week or so, you change out the pad. Each day, you scoop the poop, which is dried out and no (or very little) smell. We carried a litter box between the house and boat until we were sure each cat would use it properly, then used one of the same in each place. The pellets don't get pushed out and tossed around like the sandy clumping litter, so less mess to deal with.
This is worth the time to get the kitty comfortable with the boat. Our cats have also walked on a leash, so we could roam the docks or explore ashore. While I like dogs just fine, a cat on the boat is a great companion and doesn't have to "go to shore" three times a day. Walks become a fun outing, not a necessity.
Hope that helps.
Jim
Jim,
Thank you, that was most encouraging. And since we have a larger boat, she can have her own stateroom!
Jim,
Are there any life jackets for small cats?
Jim,
After following your advice, our small kitten has adopted her new role as boat captain, with my wife and I as her crew!
Thanks again!
Claus
Kaptajnen":1jydus9c said:
Jim,
I haven't seen any cat-specific life jackets. We bought a dog PFD in a small size, and my wife redid the connections on the front of it to better fit our cat. For full disclosure, none of our cats (one at a time) has liked being in a life jacket. We found our cats adapted well to boat traveling; only put the life jacket on them at first. Each of the cats quickly learned where the "best place" on the boat is, for the conditions (generally low and towards the middle of the boat when conditions get "sporting").
Over the years of traveling with our cats, we have had two occasions where we had a "feline overboard" situation, both at the dock, and both caused because of the leash getting hung up. I had each back onboard in seconds. Cats tend to be very sure-footed. Even so, we haven't let them be out of the cabin when underway (unless we have had the full cockpit enclosure on).
John
There are other threads, but I'll post this here. We are currently in the same process as we intend to do a lot of anchoring this year. 2 of our 3 dogs would not use the plastic grass. We ordered a 2'x4' tray and real sod patch. We put up doggie fencing around our patio. Start at home by training your dogs to use the sod patch. After 4 days all 3 dogs are now used to using the sod patch for elimination. The next step is to put the plastic artificial grass over the sod. We plan to keep the plastic/sod combo in place between now and our next outing on the boat. The dogs should then be used to using the artificial plastic.
