Jfrano
- Aug 12, 2018
- R-29 CB
- June Sea
Yes, so inevitably when doing plumbing you’re hit with these issues. So adding a water filter. Went to add just after the pump, had ordered some pump connectors? Which are typically not available at HD or
Lowe’s and I got the wrong kind. O ring male and 1/2 inch female
Just after pump.
So I put it all pack together as original and
The pipes leak at the plastic connectors . Some what new to the Pex world.
- Can you reconnect a pex pipe or will it leak from not having a smooth surface.
- which provides a longer and problem free life Brass push to connect connectors Or
Plastic, that boat is equipped With.
Just after pump.
