Hello Ranger Tug Factory, I have the exact same fresh water pump issue on my new 2018 Ranger Tug R-23 that many people are also having. It started with low water pressure at all faucets. I was told to clean the strainer on the fresh water pump. So I cleaned the plastic shavings out of the strainer attached to the water pump. When I re-assembled it, it still didn't work properly, so I took the inlet hose off the pump and blew air into the hose toward the tank. When I re-assembled it the second time. the pump works OK now. So it was some plastic shavings still left in the hose coming from the tank. But now these shavings are back in the Tank!
Since some of the plastic shavings are still in the tank, is this going to be a continuing problem? How can all these plastic shavings be removed from the tank? Can they be sucked out through the filler tube that goes from outside the boat into the tank, maybe using a hand pump?
Any ideas from the Ranger Tug Factory Technical people would be greatly appreciated.
