Possible small amount of seawater in my Webasto Heater R-25 Diesel Tank TIA
Lanrac62
R-25 (Outboard)
FMLT2527K233
Sin Nombre
I was using a 5-gallon plastic gas tank to fill my Webasto Diesel 4-gallon holding tank, and the container slipped out of my hands into the water. The nozzle closes automatically on this type of gas tank. Still, I am concerned that some salt water may have leaked into the container while it was in the water for about 5 -10 seconds, even though the nozzle completely closed. I was in a hurry, turned the container upside down with about 3 gallons of Diesel still in the tank, and nothing leaked out. I wiped off all the water on the spout and filled the tank. Everything was tight (nozzle cap before I started to avoid diesel leaking on my fiberglass). Are there any products that can remove the water so it does not affect my Heater over time? Several test pump kits require siphoning the bottom of the tank into a clear glass container and letting it settle for 30 minutes. If there is any water it would be at the bottom of the tank. I purchased this pump and hope that the 39" tube will go to the bottom of the Diesel tank for my Webasto. As a second option, are there any products that would break down any drops of water that possibly entered the plastic tank while it was briefly in the water? In hindsight... ugh. :-(
