POWER TO LEFT SIDE OF PANEL
arefftx
C-26
The Lone Ranger
I am hooked up to shore power & the entire left side of my electrical panel is dark, refig, berth lights, cabin lights. I was doing cleaning yesterday in the electrical switch area and might have caused the interuptions. Any suggestions?
Don’t clean. Just kidding. If everything was working ok before you cleaned I’d expose as much of the area you cleaned as possible and let it air out. You might want to use a blow dryer on a low setting to see if that removes any moisture from the area. Trust me, I’ve been there before.
If the left side of your electrical panel is like my RT25SC it is battery only and has nothing to do with shore power. Make sure the house battery switch is on in the port cockpit locker. If the switch is on you may have a loose connection or the main fuse for the panel may be bad.
Hope this helps
