WHICH BRINGS ME TO A NEW QUESTION:
My Bluetti is 170AH at 12V but my guess is that if I use it to charge the boat through shorepower, that I will be doing so at 120V, which reduces the Bluetti to sub 20AH - which sucks! Does it matter? Does the charger then convert it back to 12V so its all a wash or does it take a massive hit during the conversions?
Im hoping not to need the Bluetti to charge the boat BUT how do I charge the boat with the Bluetti more efficiently than via shorepower?
170 amp-hours * 12 volts = 2,040 watt-hours.
2,040 watt hours / 120 volts = 17 amp-hours.
It's two ways of saying the same thing, depending on the voltage.
Consider the inverter. Its purpose is to convert 12 volts DC to 120 volts AC.
The water heater draws 750 watts. Assume I run it for an hour. I'll consume 750 watt-hours. At 12 volts, 750/12 =62.5 amp-hours. At 120 volts, 750/120=6.25 amp-hours.
Personally, I don't find it very useful to think of 120volt AC on my boat in amp-hours. I do the above conversions a lot to 12 volt, since the 12 volt DC electrical system is the house battery bank, and the shunt keeps track of consumed amp-hours (at 12 volts DC).
The battery charger does the inverse. It converts 120volts AC to 12 volts DC.
I have a Kisae 60 amp battery charger. The "60 amp" is based on the 12 volt side of the battery charger. Wattage is specified at 1,050 watts.
1,050 watts / 14.4 volts = 73 amps. On the battery monitor, I will see 73 amps or less at 12 volts going into the battery.
1,050 watts / 120volts = 9 amps. So on the amp meter needle on the AC panel, I will see around 9 amps.
The Bluetti has its own inverter that's providing the 120volts AC power which you plug into the boat's shore power connector.
The spec sheet on a 2000 watt-hour Bluetti battery states 40 amp-hours. That tells me the battery they're using is 50 volts DC.
This all gets confusing because AC (alternating current) can't be stored. Electricity can only be stored in a battery operating at DC (direct current). 12 volt, 24 volt, 48, 56 volts... all DC.
An inverter gives us 120volt AC from a battery at DC.
Ohms Law: Voltage = Current * Resistance. The resistance is constant (it's in the wires throughout the boat). So as voltage goes up, amperage will go down. They are proportional to each other. As amperage goes up, it'll generate heat (from the resistance). Heat is lost power. So electrical is a balancing act. We want amp's to be low, to keep heat down, and not have a lot of lost power caused by resistance.
The USB outlets on the boat that we charge our phones with, they're 5 volts DC, by the way.
This is a great discussion, by the way. I'm currently working on a video for our YouTube channel "Electrical Overview for the R27-OB LE with LFP."
