I'd appreciate some advice on the pre-purchase survey results for a 2009 R25 with the Cummins Mercruise 2.0 QSD and Twin Disc transmission:The survey included an oil analysis. The surveyor found a "salt line" in the engine compartment and some salt residue. The oil analysis found "severe" levels of sodium in the transmission oil, along with "abnormal" level of copper. No sodium found in the engine or excess metal particulates from wear.
I'm thinking that long term, I should replace the Twin Disc transmission (model 5005A). Are these transmissions still readily available? Is a re-build a reasonable ($$) approach?
