Shano
- Jun 17, 2017
- R-23 (Sterndrive)
- Non-Fluid Motion Model
- Skagit Orca 27XLC, Sea Sport Pacific 3200
- Great Catch,
I just added this to our CW30. The last bowl was not see-thru and had an awkward drain plug. Photo is in our album. The part numbers are for the Marine Bowl: RRK15405 and for the Marine Bowl Ring: RRK15035-02. If you DIY make sure you have some "sticky grease" to hold the gasket in place while you put it together. A pretty easy modification to make so that if you get a "water in fuel" message while underway it makes it a lot easier to drain off the water in this filter (that is if you can see it). It is also easier to not make a mess! You still may have to drain off a little fuel from the fuel water separator in addition to draining this one. The sensor is on the engine mounted filter so you may want to drain that one first. The one time it happened to me was in flat calm water so it wasn't a problem but this set-up makes it a lot easier -- it is a little surprising that this is not a stock item just like it was on our last two diesel boats. I usually drain both the primary filter and the fuel water separator filter while at dock every once in a while because it is so much easier.
