ddenver
- Nov 26, 2008
- C-28
- FMLT2732K011
- Non-Fluid Motion Model
- Previously C-Dory Venture 23'
- Echo (2011 model; Yanmar 4BY2-180)
Good day.
Our "new to us" 2011 Ranger Tug 27' Echo has a ProMariner TruePower Combi 2500 watt Battery Charger/Inverter on board. All works fine when we are on shore power. However, I am afraid its not clear to my feeble brain how to get the inverter working correctly when we are NOT attached to shore power.
I found the following seemingly quite relevant partial post (I am only posting the Charger/Inverter portion of that entry) by "knotflying" in a thread titled "Shore Power Garmin 5212":
Re: Shore power and Garmin 5212
Postby knotflying on Wed Jul 08, 2015 11:01 pm
What inverter charger do you have? Our Promariner has the charger and inverter as one unit. If on shore power and you want the charger on push the rocker switch up. If you are on the hook and want 110v for your outlets or on shore power and do not want the charger on then put the rocker switch down. The center position is off.
The above seems fairly straight forward but, as mentioned, I cannot get our unit to invert. Perhaps I am not setting things correctly between the switch on the Charger/Inverter unit itself and the similar Remote Control connection Rocker Switch located by the helm seat.
While disconnected from the shore Power 'umbilical cord' I have tried the two sets of rocker switches in seemingly all combination of positions but have not been able to get the Inverter working. As I understand the inverter, I should be able to flip the A/C master panel switch on when in the required 'rocker switch down' position and see the A/C indicator come alive as if we were connected to shore power. However; this is not the case for us.
Any further suggestions to ger our ProMariner unit Inverting would be greatly appreciated.
Thanks!
Take care,
Dan, Tanya, and Hannah on Echo
Thanks!
Take care,
