seashanti
- Feb 24, 2015
- C-24 C
- Non-Fluid Motion Model
- Cutwater 28 (2015)
- Sea Shanti
We purchased a 2015 Cutwater 28 with the Garmin 7212 chart plotter. We've recently (during the last 2-4 weeks) experienced a problem with the GPS signal. I've noticed that if I take the boat out in the morning when it is relatively cool (in the low to mid-60s) that everything works. However, in the afternoon when the temperatures have been in the low to upper 80's the chartplotter does not receive a GPS signal, however, everything else works. I initially thought that the problem may be with the GPS antenna. So I replaced the antenna and it didn't make a difference. So then I thought that the high temperature may be the problem so in the afternoon I opened the front hatches, added a fan, opened the head door and the panel behind the chartplotter and often the GPS signal appears after a period of time.
When I recently had the boat at Bellingham Yacht Sales, where I purchased the boat, the service manager checked all the connections and they all looked good. I have to say that I am very impressed with his knowledge and support regarding this problem along with a few other issues.
I'm interested if anyone else has had similar problems that they solved or have any suggestions.
Mike
Sea Shanti
Mike
Sea Shanti
