JSimmons
- May 31, 2022
- R-23 (Sterndrive)
- FLMC3054D818
- Fiska
I had all new batteries installed on my 2018 30S. I am not sure the connections were correct.
1. When shore power is not connected, the indicator lights on a portion of the 120V panel are faintly illuminated. I am pretty sure this was not the case before the battery change. I didn't think too much about this because everything seemed to be working fine. But, it does seem strange that some power is finding it's way into the 120v panel. Does anyone have a perspective on this?
2. Is the Garmin chart plotter powered by the house batteries? I don't think this was the case before my battery change but it is definitely that way now. (I say, "I don't think so..." as the boat is fairly new to me and I can't remember if the Garmin powered up from the house bank). Can someone tell me which way it should be?
3. So, the real reason I am posting these questions is because shortly after the new batteries were installed, my inverter/charger failed and had to be replaced. The failure was that no 120v shore power would get to the 120v panel. OK, well things can fail, so I soldiered on. However, today, after only a month, the new inverter/charger has also malfunctioned causing my house batteries to go flat (no idea if it will solar charge as the boat is kept in a boat house). This seems more than a coincidence. I am wondering if the battery re-install and these failures could be related. I would be interested (and grateful) for the perspectives of forum members.
