ProMariner 2500QS Replacement
JerryE
C-302 SC
FMLT2551C909
R-25 Classic
Alto
The ProMariner TruePower 2500 watt Combi 2500QS inverter charger on my 2013 RT R31 died. ProMariner no longer makes it, as they now offer 2000 watt models, instead. Should I replace the 2500QS with a reduced wattage (2000) ProMariner using their pure sine wave-2000PS or the modified sine wave-2000MS? Comments in the forums seem to favor the pure sine wave to work better with TVs, coffee makers, and sensitive electronics, etc.
Or, should I look for a 2500 watt inverter charger, and if so what? The newer R31s appears to use a KISAE inverter charger (model & wattage unknown to me)–would you advise this as a replacement? If so, which model and do I then need to rewire? Finally, are there other good options you would recommend that require minimal rewiring if any? Thanks, Jerry on Alto in Marina Jack, Sarasota.
Hi Jerry,
Frankly, I would steer as far away as you can from Kisae. They just aren't reliable and I have seen SO many RT/CW owners have issues with them, including myself! I would highly recommend Victron if it fits in your boat and your budget. I went with the MultiPlus II 3000w / 120amp version:
https://www.victronenergy.com/inverters ... ltiplus-ii
Alternatively, if your boat needs and/or budget are less, I would look at the 2000w version of the original multiplus:
https://www.victronenergy.com/inverters ... us-2000-va
I would also highly recommend you purchase the inverter/charger from invertersrus.com, as they offer a free extended warranty, and they will configure the unit to your specifications prior to shipping it to you! Both choices are available from them currrently:
https://invertersrus.com/product/victro ... -2000-12v/
https://invertersrus.com/product/victron-pmp482305100/
Dave
