Promariner QS 2500
bill46
C-302 SC
FMLT3107F314
Radio Active
My Promariner QS 2500 is overcharging, went over 15 V and stayed. Inverter works normally. Any Ideas?
Bill 2014 R31CB
Try changing the battery type and see if the charge voltage changes. After having problems with mine recognizing shore power (bad power transfer switch), I quickly learned after talking with Promariner that these units are black boxes (no serviceable parts). If your problem continues, see it as an opportunity to dish the combi and get a separate charger and true sine inverter.
Bill 2014 R31CB
Hey Bill,
I would agree with the statement above, you could also use the Kisae combo unit we use now. Nice compact design and also a great customer service department. Hope this helps.
Turned the switch while off, removed and replaced remote cable. Looked a little corroded.
Seems to be behaving now went to 14.1,, then dropped to 13.3. Proper for AGM 1.
Will look at Kasie.
Bill
