knotflying
- Jul 25, 2010
- C-28
- FMLT2731J011
- Non-Fluid Motion Model
Well, so much for our protective skeg thread. I got pushed by the wind up against a rock underwater and dinged the prop. I carry a spare, so I pulled the boat and pulled the prop. My question is on the re-installation. I got it back as far on the shaft as I could. I tightened the retaining bolt and then tapped around the perimeter with a hammer and block of wood and continued to tighten the bolt. I can't snug it up anymore, but it does not seem to be as far back on the shaft as the original. Does anyone have any comments or advice?
Mike Rizzo
PS. I used the Pro Pull 103 Prop Puller and it worked great.
Mike Rizzo
