RobMcClain
- Sep 29, 2013
- PNW
- C-30 S
- FML30C02J122
- Freedom 3.0
I have a 2022 Cutwater 30. At 5 am this morning my propane alarm started beeping. No smell of propane. We had used the oven 12 hours earlier but shut down the system after use. Have never had a problem with the stove and never had an alarm before. It would reset but 30 seconds later start beeping again. After a few resets it stopped resetting so I had to pull the fuse to stop it. I know the problem could well be the sensor in the bottom of the stove cabinet and it has to be replaced, but before I do this is there anything else I might try? I disconnected and reconnected the tank and no change. When I reinsert the fuse the sensor shows green but a short time later it goes red and starts beeping again. Any thoughts outside of replacing the sensor?
Rob
Rob
