On my boat, next to the stove, there is a round propane sensor. On the sensor there is a green light that is always on. This indicates the sensor is powered up. When we want to use the propane, we open the gas cock on the cylinder and then go back to the stove and press a button on the sensor which then shows two green lights, indicating the the sensor is on AND the solenoid is activated. Note: when the solenoid is activated, it is hot to the touch and allow propane to flow. That is one way you know it is working (hot solenoid).
Awhile back, I noticed my starter battery depleting quickly. I ended up replacing it and found the battery I pulled out was actually just find (load tested). I assumed the propane sensor was drawing down the battery, down so I planned to put in a switch that would completely shut off power to the sensor and solenoid (mounted on the battery) so that I could turn it to off when propane was not needed.
I got into the project a couple weeks ago and before starting it I did a thorough inspection of the current sensor switch and solenoid. I found that the solenoid was stuck in the "on" position. I determined this because whether the sensor switch was showing one green light or two, the solenoid remained hot and we could still use the stove.
After checking and cleaning everything up, it seemed the solenoid was no longer stuck in the on position. Now when the switch is on, the solenoid is hot to the touch. When the switch is off, the solenoid is cool.
Also, now when the switch is off, although there is still a green light on, I cannot detect much of any battery amperage dropping over night. Recently, when we have forgotten to turn the switch off, there was a noticeable depletion of the battery.
Takeaway - If you starter battery seems to b not holding a charge, check to see if you propane solenoid is warm (when the sensor indicates it is off). Also, as I've mentioned in other posts, get yourself a battery load tester. It take a lot of the guess work out and you won't end up buying a battery when you didn't need to!
Hope everyone is staying warm.
Bobby
