Question of the day...
johnniethek
C-30 S
FMLT29211617
Salish Searcher
I may need to replace the starting battery for my R-29S sooner than later. What kind of battery do you folks recommend?
Thnx,
Johnnie the K
Hi there Johnny,
The battery that came with your boat was specifically selected for that application and going with the same one should still serve you well. Of course, there are lots of others depending on what you are trying to accomplish or if you feel that the needs for the battery have changed (lots of very cold or hot weather use, etc.) but if you are doing regular cruising, the stock battery will do just fine. Hope this helps
Thanks!
Ralf
Thanks. I appreciate your response.
How do I find out the make and model of the battery that was initially installed on my 2017 R-29S?
John
Wow, I’m actually going to publicly disagree with Ralph this time.
Back in 2017, FM was using Universal Power UB121xxx AGM batteries unless you had the expensive lithium upgrade.
Universal Power batteries are among the cheapest AGM batteries out there. They are deep cycle batteries which is the type you want for the house bank. FM was using a one size fits all philosophy in buying batteries.
The UP batteries were not a good choice for use as an engine or thruster battery though. Dozens of threads on this forum about MUCH, MUCH better starter type AGM batteries for use in those roles. You want lots (900+ CCA) of power for starting or the thruster. The Odyssey, X2Power and Optima AGM starting type batteries are frequently mentioned.
Our 2017 C-28 uses Group Size 31 batteries. I am not sure what group size are used in the RT-29.
On my C-28, I replaced the original six year old Universal Power AGM for both engine and thruster batteries the first month I owned the boat. Still have newer UP batteries the seller installed in the house bank though. The UP batteries are ok (but not great) in that role.
PS: Heard from both a 2019 R-29 and 2017 R-29 owner that you have Group 31 sized batteries in your 2017 R-29S. The battery cables should be labeled near where they connect to the battery terminals. If you go with a different brand starter battery (like one of those mentioned above) you may need battery terminal adapters but those are easy to find and inexpensive.
Thank you so much for this. The boat is a couple hours, including a ferry ride, away so I couldn’t check it myself, And the owner’s manual here doesn’t have the info.
Last summer I replaced all six original equipment batteries in our 2021 R29S with West Marine Group 31 Dual-Purpose AGM Batteries, 105 Amp Hours. Engine started easier, thrusters worked better, and house batteries outperformed the originals.
West Marine Model #15020258 / MFG # WM8A31DTM
Manufactured in US by East Penn
Cold cranking amps = 800; marine cranking amps = 1000
