dbsea
- Oct 1, 2021
- R-23 (Outboard)
- HALCYON
Hi All,
I've noticed some quirky behavior on my inverter charger. Each time I plug in, I follow the same procedure :
1) ensure AC breakers are off
2) ensure Inverter is off
3) ensure AC ELCI is off
4) plug in shore power to boat
5) switch on power at pedestal
6) switch on AC ELCI
7) switch on Charger
Perhaps once in every 5 times I return to the dock, when I follow the above procedure, I can see that there is 120V AC coming to the boat from the cable using my voltmeter, and the AC ELCI indicator is green, and my AC breakers work, but the ProMariner is not kicking on, and the AC Amps on the panel Voltmeter are registering ZERO. Each time this occurs, I leave it, and approx. 10-15 mins later, the charger kicks on. I've gone over the manual 2-3 times and can't find anything that would indicate that this is a "feature." Has anyone else experienced this or have any insights?
