SlackwaterJack
- Aug 15, 2009
- C-24 C (Sterndrive)
- Slackwater Jack (2005)
Hi,
My '05 R-21 is set up with a Guest 6 amp charger and a BalMar Digital Duo-Charge. The Balmar installation instructions show only a 2 battery setup WITHOUT an "off/1/2/both" selector switch. But my boat has a selector switch...is that correct? or was this something that the previous owner added on his own? Judging by the amount of jury rig wiring the PO performed when he self installed some accessories (for example: an unfused wash down pump was tapped into the running lights) it wouldn't surprise me. I spent a lot of time the last few days properly supporting and tying-up loose wiring.
I'm planning on relocating the batteries from their present location inside the engine cover and want to know if I should remove the selector switch (located in the starboard pilothouse cabinet) while I'm at it or replace it with a locking off/on switch so I can shut off DC power to everything including the engine (not the bilge pump or accessories with memory).
Just curious...
Whose idea was it to require the removal of the batteries to reach the water intake shut-off valve (to even see if it's open or closed !) or to inspect/adjust the shaft packing? Also, the charger/and Balmar units aren't supposed to be installed where temps might exceed 120deg, when charging, batteries give of hydrogen gas (boom!) and they also don't like heat, plus all that short/spark/flash hazard is beside the fuel tank in a small enclosed space...or am I just paranoid?!
Just curious...
