tlkenyon
- Sep 30, 2010
- R-25 SC
- Non-Fluid Motion Model
- 3 kayaks, 1 canoe; R-21 (Nellie May I)
- Nellie May
Nellie May is a 2005 R-21 Classic with the 3YM30. The previous owner installed a water temp gauge, so it is possible to see what is going on in real time. He also installed an oil pressure gauge (50 psi above idle). The water temp usually runs at 160 degrees F, up to about 3,000 RPM, where it starts to climb. Above that, the temp climbs steadily, reaching somewhat of a plateau at 190 @ about 3500. WOT is about 3,850 or so and the within about 2 or 3 minutes at that speed (about 9 mph by GPS) the temp climbs to 205 or so and the high temp alarm goes off.
The closed-loop cooling system is full of anti-freeze. There is no unusual exhaust color, except it gets kinda steamy at WOT. There is a lot of fresh water going thru the system. Upon inspection, the pump impeller shows no wear. I took the screen out of the fresh water strainer and ran without it (in clear, 50 degree springtime water) to see if less restriction in the system would help. Nope. The engine has about 190 hours.
It this normal? Is the cooling system just inadequate to deal with the WOT temp load? Would a bigger pump and bigger hoses assist? We expect to do some river travel and may need WOT for more than just 2-3 minutes at a time.
A search of TugNuts did not reveal info on this topic for the 3YM30 (that I could find). Thanks in advance for the information.
TK
TK
