tlkenyon
- Sep 30, 2010
- R-25 SC
- Non-Fluid Motion Model
- 3 kayaks, 1 canoe; R-21 (Nellie May I)
- Nellie May
Lately, I have been noticing a new vibration at certain speeds. I could not find the source, and kinda wrote it off as perceived and not real. This evening when I put the boat up on the lift, I went underneath to just take a look. Maybe there was a ding in the prop, or some line on the shaft, or something.
In tugging on the prop shaft, I noticed that the starboard set screw was very loose, to the point of almost coming completely out. I tightened it and its port partner, which was also loose. I then noticed that the collar on the shaft just forward of the prop seemed to be sticking out of the hull further than normal. I thought I had previous photos for comparison, but do not.
A photo of the situation is attached (OK the hull needs some cleaning...a few months of freshwater ick).
So...could the collar have worked itself aft? Should I loosen the set screws and slide (tap, push) the collar forward some distance? Is it OK as is? I have not yet gone out to see if the vibration is gone, I wanted to hear from an expert first....
Thanks in advance.
Thanks in advance.
