BlueDragonfly
- Jun 14, 2011
- C-24 C SE
- Blue Dragonfly
I was just considering the impending (first time) winterization process and taking stock of some of the parts I've accumulated. I remember reading (in tugnuts) someone recommended that for really cold weather, the water impeller should be removed as it would inevitably become brittle and be damaged from the cold. If anyone has done this; wouldn't all the pink antifreeze that you just added seep out in the process? The logic for removal is sound and I want to do this. Can't remove impeller prior to cranking PINK thru, and the relative position of the impeller suggests that I'll loose most of my fluid if I try and remove. Did you solve this?
By the way, I managed to pass 100 hrs on the Yanmar in my first summer! Is anyone else getting these numbers or should I be checking the counter?
Roger
Roger
