R-21EC 3YM30 gauges possible?
Kamalani
C-24 C SE
FMLT2122
Kamalani
Is anyone familiar enough with the 3YM30 to tell me if it is possible to add Oil Pressure & Coolant Temp gauges in addition to the factory alarms? Either using auxilliary sender locations on the engine, or by paralell signal wiring to the existing senders?
You can make up T Connections and disconnect the existing sending units then put the T where the sending unit came from and put the old and new sending units into each end of the T... This way you have your gauge and the original working together... I believe the pipe size is 3/8" but check first...
Wilkie
The oil pressure gage sensor hookup is straight forward and easy. Water temp gage sensor is a bit more difficult because of the pipe fittings needed to come off the engine and mount the sensor.
gene
I have a Garmin 750S chart plotter/fish finder which will connect to a NMEA 2000 system. This enables you to input various information into the Garmin or other brand NMEA 2000 compliant unit, Your Raymarine unit should accept the input from a NMEA 2000 system.
Maretron manufacture an analogue engine monitoring system which has a wiring harness to connect straight into the Yanmar 3MY30 engine. The unit is EMS100 and the wiring harness is EMSYMR01. You also need some NMEA 2000 cable and fittings to connect the EMS100 to, in my case the Garmin 750, or whatever display unit you have.
There are many different lots of information you can feed into your display, oil pressure, cooling water temperature, and with the correct sensing units fuel flow, fuel tank level, water tank levels, even ocean/river water temperature etc. Maretron also make a small display if you want to have a separate display other than your chart display unit.
If you go to :-
http://www.maretron.com/products/pdf/EM ... _Sheet.pdf (this is the data sheet)
or
http://www.maretron.com/support/manuals ... UM_1.0.pdf (this is the manual)
You will find more information on the equipment. There is also a list of the Yanmar engines which the unit suits. You can add to the system later if you want other data displayed.
In Australia where I am, the cost for the EMS100 and Harness is about $Aus1100 plus the NMEA cabling and fittings.
It maybe a lot cheaper in the US, for many things we seem to pay a premium over here.
Geoff
