Subject: R-21EC's ProMariner charger and battery relay box
I'm wanting to understand the actions of the engine battery charger's black relay box and Thermal Circuit breaker.
Here are the photos of the relay box and Thermal circuit breaker on my R-21EC.
The reason I'm posting is that I've had the 'slow flash' green LED twice now and have had discussion with Kenny Marrs about this.
The 'slow flash' I've had was because I had left my boat at the dock/slip on two occasions without shore power connected to the ProMariner battery charger.
1) For one week without shore power and main battery switch in helm electrical cabinet/locker in the ON position and Refer set at #3.
2) For two days without shore power and main battery switch in helm electrical cabinet/locker in the ON position and Refer set to #0 (i.e., OFF)
Each time I've returned to the boat under conditions 1) & 2) at my dock the black relay box has shown the 'slow flash' green LED. According to the label on the relay box the 'slow flash' is not an indication one or both batteries are at or below 9.5 volts. It some other cause which I don't really understand.
My understanding is that if I see the 'slow flash' then the running engine cannot charge the house battery. This was evident as when running the engine under conditions 1) & 2) none of my 12v accessories (such as Chart plotter and cabin lights) would light up.
My understanding from Kenny is that the black box relay is a safety device that stops the engine/alternator from charging the house battery if it's below a certain voltage. Why is this ? I would think the engine/alternator should charge the house battery if its voltage level is low.... but dunno if this can cause a safety issue. Can others here explain the purpose of the black box relay operations ?
Also, anyone care to explain what the Thermal Circuit breaker is all about ?
The reason I had situations 1) & 2) was because I was waiting for my Marino 12' shore power cable to arrive. My Marina insists my R-21EC use a standard shore power cable connected to the dock's power pedestal. Now that I have this shore power cable the boat is left connected to shore power and I hope never to experience situations 1) & 2) again.
I also, per Kenny's advice will always have the main battery switch in the OFF position to ensure no 12v accessories are drawing power when on shore power and boat left there for a while. Just the batteries will be kept charged. Of course Refer will not have food items but may have bottled water and soft drinks left inside. This means unfortunately I can no longer leave my Caframo Dehumidifier running in the cabin via a 150 watt inverter connected to the 12v cig lighter receptacle.
Any insights to the above enquiry are welcomed. Thanks..... 🙂
