SgtAlf
I had the engine pod bilge pump installed a couple of years ago. I hadn't thought much about it until lately. I popped open the inspection plate and found the pod half full of water. I checked the fuse, blown. I didn't have a 7.5, so I installed a 10 until I could get some 7.5's. Got the 7.5, went to replace the 10, and the 7.5 blew. I checked the 10 and it was blown. OK, lets try a 15, the pump sounded like it came to life, but only for a second. I pulled the fuse and tried again, several times. Same result. I checked the wires, what I could see looked good. I pulled the pump body and didn't find anything that might be jamming the impeller.
Question, is there a switch that controls this pump? It appears to be hard wired to the house battery. Anyone suffer a similar problem? What could be causing this pump to be blowing 7.5 amp fuses?
Thank you,
Thank you,
